Sinumerik Alarm 16796 Channel %1 block %2 coupling not defined
A coupling is to be switched the parameters of which have neither been programmed nor configured.
Please inform the authorized personnel/service department. Correct NC part program or MD, program the coupling with COUPDEF or configure by means of MD.
