Sinumerik Alarm 16787 Channel %1 block %2 coupling parameter not changeable
The specified coupling is write-protected. Therefore, the coupling parameters cannot be modified.
– Alarm display. – Interface signals are set. – Interpreter stop – NC Start disable in this channel.
Please inform the authorized personnel/service department. • Remove write protection. Channel MD: COUPLE_AXIS_IS_WRITE_PROT • or modify part program.
