Sinumerik Alarm 16700 Channel %1 block %2 axis %3 invalid feed type
In a thread cutting function, the feed has been programmed in a unit that is impermissible. 1. G33 (thread with constant lead) and the feed have not been programmed with G94 or G95. 2. G33 (thread with constant lead) is active (modal) and G63 is programmed additionally in a following block .conflict situation! (G63 is in the 2nd G group, G33, G331 and G332 are in the 1st G group). 3. G331 or G332 (rigid tapping) and the feed have not been programmed with G94.
Use only the feed type G94 or G95 in the thread cutting functions. After G33 and before G63, deselect the thread cutting function with G01.
