Sinumerik Alarm 16422 Channel %1 block %2 angle %3 programmed repeatedly in the block
%3 = Angle
It is not allowed to program more than one rotation angle THETA for the orientation in one block. The angle of rotation can either be programmed explicitly with THETA or by programming with Euler angles or RPY angles.
Modify part program.
