Sinumerik Alarm 16015 Channel %1 block %2 wrong axis identifier %3
%3 = Axis name
Axis names from different coordinate systems were used to program axes for LIFTFAST. The retraction movement is no longer clear.
Use axis names from one coordinate system.
