Sinumerik Alarm 16010 Channel %1 block %2 machining stop after lift fast
LIFTFAST without interrupt routine (Asup) has been programmed. The channel is stopped after the lift motion has been carried out.
After the channel stop, the axes must be retracted manually in JOG and the program aborted with Reset.
