Haas Alarm 910 APC-PROGRAM CONFLICT – Haas Mill
Alarm: 910 APC-PROGRAM CONFLICT – Haas Mill
The subprogram you are trying to run is not assigned to the loaded pallet. Another program is assigned to this pallet in the Pallet Schedule Table. Either enter the required program name into the Program Name column of the Pallet Status Table, or remove M48 from the subprogram you want to use. Verify that the subprogram and the pallet are compatible.
