Yasnac Alarm 415 SUBPROGRAM ERROR
Yasnac Alarm Description
G25 is programmed in canned cycle mode. M98 or M99 is programmed in the block containing G25. Addresses P and Q are not programmed in the block containing G25. Sequence numbers specified with P and Q are not in memory. G04 is programmed in the block containing M98. P is not programmed in the block containing M98. Sequence number specified with P is not in memory. Sequence number specified with M99 P…* is not in memory. G25 is programmed in the end block of program copied by G25. More than eight levels are commanded by G25, M98 or using them jointly in subprogram.
Applies to
Yasnac CNC Controls 3000G
