Tensor Cad Cam Simulator for Fanuc Haas Heidenhain Free Download
By Date March 4, 2013
TensorCadCam
Tensor CadCam is an easy-in-use CadCam software.
Tensor CadCam generates CNC-code from drawings for milling lathe, Wire-EDM, waterjet- and lasercutting.
CNC-code is generated for any controller like Haas Fanuc, Heidenhain, Siemens, Mitsubishi, Fagor and many more.
Using Tensor will increase speed, accuracy,flexibility of all your CNC-jobs. No more programming-problems and stoppage losses in your toolshop with straightforward, easy-in-use CadCam software.
  • For CNC milling and lathe
  • Supports import,export of Dxf and Iges
  • Powerful 2D and 3D features
  • Also made for Wire-Edm, lasercutting, torchcutting
  • Very easy in use Cad and CadCam-software
  • Powerful dialog-controlled CNC programming
  • Clear software with limited menus and buttons
  • Script-language available to customize your CadCam system
TensorCadCam is an intuitive, fully equipped with easy to use machining wizards that take you through 2.5 & 3 axis machining features for milling- and lathe-jobs. Thanks to wizards, you will eliminate the guesswork from CNC-programming.
A full assortment of 2D and 2.5D Axis milling and lathe features gives you effective and cycle time reducing options to work with for even the most complex programming situations. The CNC-code can then be simulated in the powerful Tensor NC-simulator for visualization for miling and lathe programs.
Tensor Cad Cam
Tensor Cad Cam
Download
Free Download following softwares
Tensor NC-simulator Lathe
Tensor NC-simulator Milling
TensorCAD drawing software
TensorCADCAM Lathe
TensorCADCAM Milling
Leave a Reply
Submit Comment
