Sinumerik Alarm 75005 Channel %1 block %2 CLC: General programming error
%2 = Block number
The activation/deactivation command for the clearance control “CLC(..)” accepts only the values 2, 1, 0 and -1 as call parameters. This alarm signals that parameters are incorrect or missing. The activation command CLC(2) with monitoring of sensor collision signal is accepted only if a valid digital input is configured for the monitoring signal in MD $MC_CLC_SENSOR_TOUCHED_INPUT.
Modify part program. Modify part program. Configure digital input for collision evaluation in MD if necessary.
