Sinumerik Alarm 61803 Channel %1 block %2 programmed axis not present
The programmed axis is not in the system. Alarm triggered by following cycles: CYCLE83, CYCLE84, CYCLE840.
Check parameter _AXN. Check MD20050-20080.
