Sinumerik Alarm 310771 Axis %1 drive %2 gain in fine area of valve characteristic is less than or equal to zero
%1 = NC axis number
The gradient in the fine area of the valve characteristic is less than or equal to zero.
The gradient in the fine area is calculated as follows:
• Positive quadrant: (MD 5464 – MD 5480) / (MD 5465 -5481)
• Negative quadrant: (MD 5467 – MD 5483) / (MD 5468 – 5484) Enter a valid combination in the above drive MD.
