Sinumerik Alarm 310710 Axis %1 drive %2 distance-coded scale incorrectly parameterized
%1 = NC axis number
If a distance-coded scale is selected (MD 5011 bit 7=1) a length measuring system must also be configured (MD 5011 bit 4=1).
– Mode group not ready.
Check and, if necessary, correct MD 5011: ACTUAL_VALUE_CONFIG (actual value sensing configuration).
