Sinumerik Alarm 310612 Axis %1 drive %2 force limitation off
%1 = NC axis number %2 = Drive number
The force limitation is deactivated. Cause: The force limitation is deactivated but:
• The NC has defined a force limit or
• Travel to fixed stop is selected.
– Mode group not ready.
Activate power limitation: Modify MD 5241: Set bit 0.
