Sinumerik Alarm 310611 Axis %1 drive %2 pressure sensor failed
%1 = NC axis number
Power limitation or friction compensation is activated: Modify MD 5241: bit 0 or bit 1 is set and both actual pressure values are less than 2% of the system pressure in MD 5101: WORKING_PRESSURE on performance enable. Cause: Pressure sensor or connecting cable defective.
– Mode group not ready.
Check the connection of both pressure sensors. If no pressure sensors are installed:
• Deactivate the force limitation: Modify MD 5241: reset bit 0
• Deactivate friction compensation: Modify MD 5241: reset bit 1
