Sinumerik Alarm 310606 Axis %1 drive %2 external valve voltage supply failed
%1 = NC axis number
The external 26.5 V supply is monitored for undervoltage in the closed-loop control. Check the monitoring criteria:
• Voltage range (average) 26.0 V to 27.0 V
• Ripple factor 240 mVss
• No voltage failures
– Mode group not ready.
