Sinumerik Alarm 301713 Axis %1 drive %2 resolution SSI direct measuring system invalid
%1 = NC axis number
Configuration of the direct measuring system is faulty for SSI encoder: MD_1032 $MD_ENC_ABS_RESOL_DIRECT must not be 0.
– Mode group not ready.
• Set MD_1032 $MD_ENC_ABS_RESOL_DIRECT to the correct value:
• Rotary encoder: Singleturn resolution (increments per revolution).
• Linear encoder: Resolution of an increment (in nanometers).
