Sinumerik Alarm 301707 Axis %1 drive %2 parameterization of modulo value for safe cam (SN) invalid
%1 = NC axis number
The cam modulo range parameterized for a rotary axis via MD 1305: $MD_SAFE_MODULO_RANGE (actual value range for safe cam with rotary axes) violates the rule stating that only integral multiples of 360 degrees may be set.
– Mode group not ready.
Please inform the authorized personnel/service department. Change parameterization of the cam modulo range in MD 1305: $MD_SAFE_MODULO_RANGE (actual value range for safe cam with rotary axes).
