Sinumerik Alarm 301706 Axis %1 drive %2 parameterization of cam position invalid
%1 = NC axis number
At least one of the parameterized cams enabled via MD 1301: $MD_SAFE_FUNCTION_ENABLE (safe functions enable) does not comply with the rule stating that cam positions are not allowed to be within the tolerance range around the modulo position. The valid tolerance range is: • With inactive cam synchronization (MD 1301 bit 7 = 0): Lower modulo value + POS_TOL <= cam position Upper modulo value - POS_TOL > cam position • With active cam synchronization (MD 1301 bit 7 = 1): Lower modulo value + POS_TOL <= cam position Upper modulo value - POS_TOL - CAM_TOL > cam position Explanations: • POS_TOL: Actual value tolerance (MD 1342: $MD_SAFE_POS_TOL (actual value tol- erance cross-comparison)) • CAM_TOL: Cam tolerance (MD 1340: $MD_SAFE_CAM_TOL (tolerance for safe cams)) • Upper/lower modulo value: is determined by MD 1305: $MD_SAFE_MODULO_RANGE (actual value range for safe cam with rotary axes)
– Mode group not ready.
Please inform the authorized personnel/service department. Check parameterization of the cam positions in
• Modify MD 1336: $MD_SAFE_CAM_POS_PLUS (plus cam position for safe cam) and
• Modify MD 1337: $MD_SAFE_CAM_POS_MINUS (minus cam position for safe cam) and perform POWER ON.
• Modify MD 1305: $MD_SAFE_MODULO_RANGE (actual value range for safe cam with rotary axes).
