Sinumerik Alarm 300737 Axis %1 drive %2 configuration of two EnDat encoders not possible
%1 = NC axis number
The MCU hardware does not allow two absolute encoders to be connected on one axis with the EnDat interface.
Please inform the authorized personnel/service department. Disconnect one of the two absolute encoders: Replace the motor measuring system by using another motor or use another encoder for direct measuring system. Correct the corresponding entries in MD 1011: $MD_ACTUAL_VALUE_CONFIG (actual value sensing configuration IM) or MD 1030: $MD_ACTUAL_VALUE_CONFIG_DIRECT (actual value sensing configuration DM).
