Sinumerik Alarm 300734 Axis %1 drive %2 zero load current less than or equal to zero
%1 = NC axis number
The value in MD 1136: $MD_MOTOR_NOLOAD_CURRENT (motor no-load current) is less than or equal to zero.
Please inform the authorized personnel/service department. For standard motors: Reset the drive (delete the bootfile) and repeat the startup. For third-party motors: Check and, if necessary, refer to the motor data sheet to correct MD 1136: $MD_MOTOR_NOLOAD_CURRENT (motor no-load current).
