Sinumerik Alarm 300609 Axis %1 drive %2 encoder cut-off frequency exceeded
%1 = NC axis number
Actual speed value exceeds encoder limit frequency fg,max = 650kHz; fg = nist * MD 1005
– Mode group not ready.
• The wrong encoder may be in use.
• Correct MD 1005: Does the number of encoder lines match the setting in MD 1005 $MD_ENC_RESOL_MOTOR (encoder resolution for motor measuring system)?
• Is the motor encoder cable connected correctly?
• Is the motor encoder cable shield installed flat?
• Replace the motor (the encoder is defective).
• Check the encoder, encoder cable and shield connection for loose contact or cable breakage.
• Replace the encoder.
• Replace the 611D control module.
