Sinumerik Alarm 27093 Checksum error NCK-SPL, %1, %2, %3
%1 = Extension indicating the type of error
%2 = Extension indicating the reference variable
%3 = Extension indicating the actual variable
A checksum error has occurred in the NCK SPL. The file /_N_CST_DIR/_N_SAFE_SPF was subsequently modified. The safe programmable logic (SPL) in the NCK may be corrupted. Parameter %1 indicates the type of modification:
• %1 = FILE_LENGTH: the file length has changed.
• %1 = FILE_CONTENT: the file contents have changed.
• %2 specifies the reference variable (file length, checksum of file contents), %3 specifies the actual variable which is calculated cyclically.
Check the file and the time of the last modification to the file. Reload the original file and start the monitoring system again with a Power On.
