Sinumerik Alarm 25105 Axis %1 measuring systems differ considerably
The two measuring systems differ considerably, i.e. the cyclically monitored actual value difference between the two measuring systems is greater than the associated tolerance value set in the machine data $MA_ENC_DIFF_TOL. This can only occur when both measuring systems are active ($MA_NUM_ENCS = 2) and referenced. The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
– Mode group not ready.
Please inform the authorized personnel/service department. Check machine data for the active, selected encoders. Check the machine data relating to encoder ($MA_ENC_DIFF_TOL) tolerance.
