Sinumerik Alarm 25042 Axis %1 standstill monitoring during torque/force limitation
The defined end position was not reached within the time specified in the machine data.
– Mode group not ready.
• If the drive torque (FXST) was set too low with the result that the force of the motor was not sufficient to reach the end position -> increase FXST.
• If the machined part is slowly deformed, there may be a delay in reaching the end position -> increase MD 36042 FOC_STANDSTILL_DELAY_TIME.
