Sinumerik Alarm 22020 Channel %1 block %3 spindle %2 gear step change position not reached
%2 = Spindle number
%3 = Block number, label
Through the configuration of MA_GEAR_STEP_CHANGE_ENABLE[AXn] = 2, the spindle is traversed to the position stored in MA_GEAR_STEP_CHANGE_POSITION[AXn] before the actual gear step change. The required gear step change position has not been reached.
Correct sequence in the PLC.
