Sinumerik Alarm 20204 Channel %1 PUTFTOC command not allowed with FTOCOF
A tool fine compensation has been written for channel %1 with PUTFTOC. The tool fine compensation is not active in this channel. FTOCON must be active in the target channel of the PUTFTOC command.
Correct the program in the machining channel: Select FTOCON so that the channel is ready to receive the PUTFTOC command.
