Sinumerik Alarm 20146 Channel %1 block %2 motion synchronous action: nesting depth exceeded
%2 = Block number
For calculating arithmetic expressions in motion synchronous blocks, an operand stack with a fixed set size is used. With very complex expressions, this stack can overflow.
Correct error in expression.
