Sinumerik Alarm 20085 Channel %1 contour handwheel: traverse direction or overtravel of beginning of block not allowed
Travel takes place on the path with the contour handwheel in the opposite direction to the programmed travel direction and the starting point of the path has been reached at the start of the block.
Turn the contour handwheel in the opposite direction.
