Sinumerik Alarm 20078 Channel %1 axis %2 programmed position is behind working area limit %3
%2 = Axis number
%3 = “+” or “-”
The axis is traversed as an oscillating axis and the target position (reversal position or end position) is located behind the corresponding valid working area limitation. The axis is not traversed.
– Local alarm reaction.
Specify smaller target position. Deactivate working area limitation. Set working area limitation differentially.
