Sinumerik Alarm 20077 Channel %1 axis %2 programmed position is behind software limit switch %3
%2 = Axis number %3 = “+” or “-”
The axis is traversed as an oscillating axis and the target position (reversal position or end position) is located behind the corresponding software limit switch. The axis is not traversed.
– Local alarm reaction.
Specify smaller target position. Modify MD for SW limit switch. Possibly activate another SW limit switch.
