Sinumerik Alarm 18400 Channel %1 block %2 language change not possible:
%2 = Block number, label %3 = Cause
The selection of an external NC language is not possible due to the reason specified. The following reasons are possible (see parameter 3): 1. Invalid machine data settings 2. Active transformation
Remedy the specified cause of the error before selecting the language.
