Sinumerik Alarm 17800 Channel %1 block %2 illegally coded position programmed
The position number n specified with the keyword FP=n is not permissible. Two absolute axis positions can be defined as fixed points via the axis-specific MD30 600 FIX_POINT_POS [n].
Program keyword FP with machine fixed points 1 or 2. Example: Approach fixed point 2 with machine axes X1 and Z2. N100 G75 FP=2 X1=0 Z2=0
