Sinumerik Alarm 17650 Channel %1 block %2 machine axis %3 not programmable
The machine axis cannot be used in an active transformation. You may be able to program the function in a different coordinate system. For example, it may be possible to specify the retraction position in the basic coordinate system or the workpiece coordinate system. The axis identifier is used to select the coordinate system.
Deactivate the transformation or use another coordinate system.
