Sinumerik Alarm 17189 Channel %1 D number %2 of tools defined on magazine/location %3 and %4
%2 = Offset number D
%3 = Magazine/location number of first tool, ‘/’ as separator
%4 = Magazine/location number of second tool, ‘/’ as separator
The specified D number %2 in the TO unit of channel %1 is not unique. The specified T numbers %3 and %4 each have an offset with number %2. If tool management is active: The specified T numbers belong to tool groups with different names.
– Alarm display. – Interface signals are set.
1. Ensure that the D numbers within the TO unit are unique, e.g. by renaming the D numbers.
2. If unique numbering is not necessary for subsequent operations, do not use the command.
