Sinumerik Alarm 17150 Channel %1 block %2 maximum of %3 NCK outputs programmable in the block
%3 = Quantity
No more than the specified number of outputs may be programmed in an NC block. The quantity of hardware outputs is defined in the MDs: 10360 FASTIO_DIG_NUM_OUTPUTS and 10310 FASTIO_ANA_NUM_OUTPUTS
Program fewer digital/analog outputs in a block. The specified maximum number applies in each case separately for analog or digital outputs. If necessary, program two NC blocks.
