Sinumerik Alarm 17130 Channel %1 block %2 analog output no. %3 not activated
%3 = No. of output
An attempt has been made by means of the system variable $A_OUTA[n] to write or read an analog output n that has not been activated by the MD 10310 FASTIO_ANA_NUM_OUTPUTS.
Please inform the authorized personnel/service department. Modify part program or machine data accordingly.
