Sinumerik Alarm 17020 Channel %1 block %2 illegal array index 1
A read or write access has been programmed to an array variable with invalid 1st array index. The valid array indices must be contained within the defined array size and the absolute limits (0 – 32 766).
Correct the specification of array elements in the access instruction to match the defined size.
