Sinumerik Alarm 16938 Channel %1 action %2 ALNX aborted due to active gear change
Sinumerik Alarm 16938 Channel %1 action %2 <ALNX> aborted due to active gear change
%1 = Channel ID
Reorganization events are, among others, subprogram abort, delete distance-to-go and interrupts, axis replacement, exiting the correction state. These events wait for the end of a gear change. However, the maximum waiting period has elapsed.
Program must be aborted with Reset and, if necessary, GEAR_CHANGE_WAIT_TIME must be increased.
