Sinumerik Alarm 16760 Channel %1 block %2 axis %3 S value missing
No spindle speed has been given for rigid tapping (G331 or G332).
Program the spindle speed under address S in [rpm] (in spite of axis mode); the direction of rotation is given by the sign of the spindle lead. Positive thread lead: Rotational direction as M03. Negative thread lead: Rotational direction as M04.
