Sinumerik Alarm 16720 Channel %1 block %2 axis %3 thread lead is zero
No lead was programmed in a thread block with G33 (thread with constant lead) or G331 (rigid tapping).
The thread lead must be programmed for the specified geometry axis under the associated interpolation parameters. X -> I Y -> J Z -> K
