Sinumerik Alarm 16510 Channel %1 block %2 no facing axis available
Diameter programming has been activated with the keyword DIAMON although no facing axis has been programmed in this NC block. If the diameter axis is not a geometry axis, in the initial setting “DIAMON” the alarm appears as soon as the control is switched on.
Please inform the authorized personnel/service department. Activate the modal G function DIAMON only in NC blocks containing a facing axis or deactivate diameter program with DIAMOF. In machine data 20150 GCODE_RESET_VALUES[28] select “DIAMOF” for the initial set- ting.
