Sinumerik Alarm 16410 Channel %1 block %2 axis %3 is not a geometry axis
%1 = Channel number %2 = Block number, label %3 = Axis name, spindle number
A geometry axis has been programmed that cannot be imaged on any machine axis in the current transformation (possibly there is no transformation active at the moment). Example: Without transformation: Polar coordinate system with X, Z, and C axis With transformation: Cartesian coordinate system with X, Y, and Z, e.g. with TRANSMIT.
Activate transformation type with TRAORI (n) or do not program geometry axes that do not participate in the transformation grouping.
