Sinumerik Alarm 16150 Channel %1 block %2 invalid spindle number with PUTFTOCF
The spindle number programmed for PUTFTOC or PUTFTOCF is beyond the permitted range for the spindle numbers.
Modify part program. Is the programmed spindle number available?
