Sinumerik Alarm 16130 Channel %1 block %2 instruction not allowed with FTOCON
• Case 1: A plane change is not allowed if the modal G function FTOCON: “fine tool compensation” is active.
• Case 2: Transformation selection is allowed only for zero transformation or transformation inclined axis, Transmit or Tracyl if FTOCON is active.
• Case 3: Tool change is not allowed with M06 if FTOCON has been active since the last tool change.
• Case 4: Orientable tool holder is active.
Modify part program: Deselect fine tool compensation with FTOCOF.
