Sinumerik Alarm 14840 Channel %1 block %2 incorrect value range for constant cutting speed
The programmed cutting speed is not within the input range
Input range metric: 0.01 to 9 999.99 [m/min]
Input range inch: 0.1 to 99 999.99 [inch/min].
Program cutting speed under address S within the permissible range of values.
