Sinumerik Alarm 14101 Channel %1 block %2 orientation transformation not active
Euler angles or a vector have been used in programming an orientation and no orientation transformation is active, i.e. the keyword TRAORI(n) (n … number of transformation grouping) is missing.
Example of correct transformation programming:
N100 … TRAORI(1)
N110 G01 X… Y… ORIWKS
N120 A3… B3… C3…
N130 A3… B3… C3…
N200 TAFOOF
Before the transformation is applied, the number of the transformation grouping must be specified with the keyword TRAORI(n) (n is between 1 and 4).
