Sinumerik Alarm 14010 Channel %1 block %2 invalid default parameter in subroutine call
In a subroutine call with parameter transfer, parameters have been omitted that cannot be replaced by default parameters (call-by-reference parameters or parameters of type AXIS. The other missing parameters are defaulted with the value 0 or with the unit frame in the case of frames).
The missing parameters must be provided with values in the subroutine call.
