Sinumerik Alarm 120201 Communication failure
The operator panel is connected with the NC and PLC via a serial bus. This alarm occurs when the communication to these components is interrupted. In connection with this alarm, all display values connected with the NC/PLC become invalid. Such faults are normal while the controls are ramping up (e.g. after resetting).
The alarm disappears automatically as soon as the fault situation has ended. If this alarm is continuously present, a wide variety of faults may be the cause. (e.g. wire breakage, NC/PLC not ramped up, faulty address/data transfer rate configuration of one of the bus nodes, etc.).
Internal
