Sinumerik Alarm 10960 Channel %1 block %2 COMPCURV/COMPCAD and radius compensation cannot be used simultaneously
Compressor types COMPCURV and COMPCAD cannot be used in combination with tool radius compensation. Only compressor type COMPON can be activated while tool radius compensation is active.
– Local alarm reaction.
Modify part program.
